current to voltage with opamp
Sharagim
Full Member level 1
I am working on DO (dissolved oxygen) circuit.
For DO probe polarization we should feed it with 700mv and I can see in this circuit the -700mv connected to "+IN" and I cant figure why.
Could you please clarify me about it ?
That's kind of an incomplete question. You don't tell us what your input is or your power supplies. But that -700mV is simply an offset (which, curiously, is going to be multiplied by the gain of your second stage.)
the OPAMP circuit acts in a way that the probe sees that -700mV.
I think your probe needs this bias voltage. This voltage will not change until you overload the circuit. It is very constant.
The first OPAMP´s output voltage is: U(O) = I(probe) * 10^7 V/A.
The second stage is adjustable.
Both outputs refer to the -700mV. So if you use a voltmeter you can connect one line to -700mV the other to the OPAMP output...
One benifit of this schematic is that the capacitanc of the probe is negligible for frequency response (but it increases noise gain)
Klaus
thx,
is there any better idea for such a probe(less noise) ?
This Probe is polarographic which we should feed with 700mv
