The first of post#5 is basically the same as the one of post#1.
The other is better suited to your needs - at least I think so.
Give more informations:
* power supply
* DAC output voltage range
* desired speed / settling time / upper frequency limit
* load resistance range
* desired accuracy, precision
* other requirements
You will find a lot of 4..20mA circuit discussions in this forum.
To ease the design I recommend a VCC referenced load
To improve accuracy I recommend to use a mosfet instead the bjt.
Klaus
