Current reference using MOS transistors and using VDD and a resistor
sathi.ec
Member level 1
Bangalore
Hi
What is the advantage of using current reference (using MOS transistors) over Current reference (using VDD and a Resistor) ? :|
Thanks
Sathi
Re: Current Reference
If you are going to look into the current value variations caused by VDD & Temperature,you will find the answer.
Best wishes!
Hi Sathi,
as we know resistor is highly affected by supply voltage. So, we will not get supply independent current/voltage reference. value of reference voltage will vary with supply and temperature.
So, we dont prefer resistor base reference circuit.
Generally we prefer BJT based band gap reference circuit because it is temperature independent
Regards,
Raj
Current Reference
but reference also depend on resistor.
hi,
We prefer current referneces using MOS rather than those made of resistors, because the temperature variation of resistors is much more than that of MOS.
Also MOS gates take lesser area then those of resistors.
thanks
sarfraz
sathi.ec said:
Hi
Thanks
Sathi
Definition of current souuce- current independent of voltage across the transistor or rersistor.
MOS can be used as voltage control current source and control by the gate voltage and the current independent of voltage across the MOS but current through resistor depend on the voltage across the resistor.
Also the drop across the resistor is more limiting swings
resistor value varies by process around 20 to 30%.,
to avoid this we will use current references.
mainly related with power supply and temperature dependence.
Transistors have high ac output resistor , so more like idea current source
To generate a current reference, you still need some kind of reference voltage block, eg Vbg etc. The generated current ref could be PTAT, CTAT or independant of temp depending on your needs.
MOS transistors are mainly for mirroring purpose. It guarantee the current reference are mirrored well to other places assuming negligible channel length modulation (big Length) and sufficient head room for them to stay in saturation over PVT variations.
Unlike a passive resistor, any fluctuation across it will be totally translated into current error.
