current-controlled current source in Spectre
ethan
Member level 3
current controlled current source
Dear everybody,
I am wondering how I can use "cccs" from analoglib in Cadence to build an ideal differential current amplifier. The cccs is two-port instance, no like vccs and vcvs, which are 4-port instances.
Which properties should I specify besides the " current gain"?
Many thanks.
current source in spectre
The controling part is the current flowing throught a voltage source. You need to specify the name of the voltage source in "the first column of the value" and be careful about the current direction.
Reactions: bellye
    bellye
current controlled current source in spectre
thanks !!!
then, how the specify the port in the third column?
