Techman_7
Full Member level 3
I am facing problem in RTC crystal oscillator circuit in automotive instrument cluster. The RTC works fine when date & time is set. The crystal oscillations are proper within frequency limits. But, sometimes the oscillations stops & the date & time gets reset.
Datasheet for crystal R38, RTC IC & circuit is attached. I have calculated the safety factor & circuit margin for crystal. These values are within limits. The Vdd supply is 5V. I2C resistors are 1K each.
What can be the root cause for it?
