CRO repair help.
linux-dude
Junior Member level 3
Hi all.
I'm repairing an old Kenwood CS-5130. The first problem was that the blanking circuit was broken, I found and replaced a dead diod. I also replaced associated caps that i suspected was the root cause, see image.
After i fixed the blanking circuit, i found another problem that confuses me. After about half the sweep X and Y axis are heavily distorted, se video.
I have checked X and Y deflector voltages and do not see anything strange. Below an image of X-deflection voltage (blue) and the blanking voltage (yellow).
Any suggestions would be greatly appreciated.
Thanks in advance,
Mike
--- Updated ---
I removed the time base circuit from the equation by using X/Y mode. The distortion remains the same.
betwixt
Super Moderator
Staff member
Advanced Member level 7
Aberdyfi, West Wales, UK
I suspect some of the horizontal timebase signal is getting back to the vertical deflection circuits. As a guess I would suspect the power supply rail has a dried up capacitor across it. Use the other scope to check the supply to the Y amplifiers.
Brian.
linux-dude
Thanks Brian.
The power rails (12V, -12V, 140V) is within 1% and less than 30mV p-p noise.
If i set the scope in X/Y mode and apply a 1Khz sinus to both channels i get this:
With this setup, the following is measured at the back of the tube:
X-plates:
Y-plates:
To my eyes the distortion on the trace is not present on the deflection plates, or am I missing something?
KlausST
Super Moderator
Staff member
off topic:
2.1MBytes is rather big file size for the "infromation" in the picutre.
As a linux guy you could just convert it to .JPG with 30% quality setup and get less than 10% of the file size.
(PNG is not good for photos)
Or use an online "picture converter tool".
Klaus
linux-dude
off topic:
Klaus
Apologies, will keep this in mind for the future!
LaTeX Commands Quick-Menu:
