dw_man
Junior Member level 3
I have a .ict file and I need to create a .CapTbl file and a .tch file. I can generate the .CapTbl file using the generateCapTbl command in encounter. Is there a similar command to generate a .tch file as well.
I also have a qrcTechFile (with no extension). Should I be using this instead?
