[SOLVED] CRC code generation problem
AliBahar
Member level 2
Member level 2
Hi friends
for DNP3 protocol crc code is generated by the following algorithm:
• Start with user data block M of k bits (k = 64 for header, 8–128 for blocks in body)
• Multiply by 65536 (ie append 16 zeros to end to form k + 16-bit number)
• Divide by generator polynomial P to obtain quotient Q and remainder R modulo-2 division is used)
• Discard Q, keep R
• Invert R to obtain R′
• Append R′ to M forming message T′ to be transmitted
Where generator polynomial:
P = x16 + x13 + x12 + x10 + x8 + x5 + x2 + 1
This forms a 17-bit number which is 13D65 (in hex)
now I have created the following C code for crc generation. but the result is not correct:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
#include "stdio.h"
typedef unsigned int uint;
typedef unsigned char uchar;
typedef unsigned long int UL;
#define WIDTH  (8 * sizeof(UL))
#define TOPBIT (1 << (WIDTH - 1))
UL POLYNOMIAL=0x3D650000;
uint  remainder = 0;
uint crcGener(uint *message, uchar nSize)
    uchar ff, bit;
    UL Rem;
    Rem=message[0]<<16;
    for (ff = 1; ff < nSize; ff++){
        Rem ^=message[ff];
        //printf("%x\n",Rem);
        for (bit = 0; bit <16; ++bit)
            if (Rem & TOPBIT)
                Rem = (Rem << 1) ^ POLYNOMIAL;
            else
                Rem = (Rem << 1);
     * The final remainder is the CRC result.
    return (Rem>>16);
void main(void){
    uint Msg[5]={0x0564,0x0DC4,0x0500,0x1A00,0x0000};
    remainder=crcGener(Msg, 5);
    //printf("%x\n",remainder);
    getchar();
unsigned char Crc8Dallas(unsigned char len, unsigned char *pData)
 	unsigned char crc = 0;
 	unsigned char i;
 	while (len--)
 		crc ^= *pData++;
		for (i = 0; i < 8; i++)
 		crc = crc & 0x01 ? (crc >> 1) ^ 0x8C : crc >> 1;
	return crc;
unsigned char Crc8(unsigned int len, unsigned char *pcBlock)
	unsigned char crc = 0xFF;
 	unsigned int i;
 	while (len--)
 		crc ^= *pcBlock++;
 		crc = crc & 0x80 ? (crc << 1) ^ 0x31 : crc << 1;
 	return crc;
thanks for response
but the length of crc must be 16 bit. the polynomial value is constant number :0x13D65. there are several methods for performing crc calculation. I must do it based on indicated method.
the message is divided by polynomial using modulo-2 division. the crc is obtained from inversion of remainder.
I did´t perform a deep analysis of your code, but at the line 17, the variable ff shouldn´t start from 0, instead of 1 ?
at the line 15, the first element of message (message[0]) is appended to Rem.
