crc 32 code explaination
aravind21tech
Hi all,
In the link below, CRC-32 is implemented in "C"
https://rosettacode.org/wiki/CRC-32#C
I can understand that 256 table entries are calculated. But I cannot get these 4 lines in that code
Code C - [expand]
q = buf + len;
for (p = buf; p < q; p++) {
    octet = *p;
    crc = (crc >> 8) ^ table[(crc & 0xff) ^ octet];
Normally in finding CRC bits are shifted 1 by 1. But 8 bits are shifted here.
Can some one elaborate the reason why 8 bits are shifted?
Why a 256 entries table is calculated?
What I meant is I can just interpret the code, but cannot able to match it with normal binary CRC calculation method.
Processing 8 bits at a time using a properly constructed table is mathematically equivalent to the one bit at a time method, but much faster. To understand the equivalence you have to study the theory of the ring of polynomials with coefficients in GF(2). The CRC is just the remainder in that ring of dividing the message polynomial by the generating polynomial for that CRC.
Thanks for the explaination, is there any link to learn about theory of ring of polynomials with coefficients in GF(2)
Just google Theory of CRC and click on the Wikipedia article. It should give you a good start.
