cpw port dimensions in CST MWS
sandeepkiranv
please help me by providing cpw feed port dimesnions in cst to exite the microstrip antenna
the cpw port dimension may vary depending on the antenna type you using. what time of antenna you using?
what i mean by antenna type is dipole, monopole, PIFA and etc..
sir its monopole antenna
hi sir m, there is no ground plane on the other side of substrate, sir i calculated the slit width and feed width i.e S and W values, my doubt is what are the waveguide port dimensions to excite cpw.
