This is the first time I've done CPS in any simulation software. So I'm not sure on ports. I have a section of CPS transmission line with a wave-port on each side, thick substrate, and no ground plane. In HFSS do I want to have my wave-port surround both traces and use two port modes? If so do I have the integration line be in the opposite direction on only one mode of one of the ports? Or is there a better way to do it with the driven terminal solver?
Or do I want to have my wave-port centered on one of the traces and the outer edge of the wave-port touch the other trace? I assume the rules for CPS port dimensions are the same as CPS?
Thanks,
Bryan
