[SOLVED] Coupling question in a rectangular waveguide cavity resonator
imbakh
Newbie level 1
Newbie level 1
i want to use coupling loop to be the coupler of a hollow dual mode rectangular waveguide cavity resonator. The question is no matter what the angle between the coupler and the magnetic field in the cavity, The H field direction in one of the mode will be parallel and the other one will be perpendicular to the coupling loop. So the S21 result will be only one ideal peak. :-(
