antenna_beginner
Hello , i am trying to implement a tandem coupler from the attached article. i have built cst the schematics as shown in the attached photo, but i have a few points in the schematics which are problematic to implement,which i signed with the red marker.
1.how to make this thin wire bridge over to port2?
2.how to make the ressistor connected to ground, iknow there is a lumped emelent in which i can define a ressistance but i am not sure if its connected to the ground or not
3. i have created a ground plane bellow the dielectrics , i have defined a waveguide port a straight rectancle at the size of the strip width, as shown in the attached photo,is the size of the port correct ,because i know that that we need to do it extra wide ,if you caould say the intutition of the port size to use ?
![Capture.JPG Capture.JPG](https://www.edaboard.com/data/attachments/68/68992-070045d8ef3bdb525e4bd782ff86084e.jpg)
View attachment 01390982.pdf
