Counting semaphore of freertos hang atmega 32
samic45mit1
Member level 3
indore
I am using FreeRTOS V9.0.0rc1 on ATMEGA32 with clock of 1159200Hz, on AVR STUDIO 7. I try to use counting semaphore in timer2 (32Khz external crystal) interrupt to handle to task. But both task run at different speed even when both having same priority. I think this is due to stack overflow.????? (Please see attachment)
My program doing this,
1. Timer 2 initialized in asynchronous mode for 1 sec interrupt.
2. Couting semaphore is created using "xSemaphoreCreateCounting" function.
3. Start_task1 is start counter "g" and run in 600ms
4. display_task is for displaying counter form interrupt handler task "d" and "h" on LCD screen, run in 300ms
5. When interrupt come (1sec), it give semaphore to handler_task1, handler_task2
6. handler_task1 take semaphore form interrupt and increment counter "h"
7. handler_task2 take semaphore form interrupt and increment counter "d"
The problem is both handler task run at different speed. For example when handler_task1 couner reach 200, handler_task2 counter at 5. Even some time display hang. I try how use counting semaphore in freertos
So please help to solve this.........
  • main.txt
