#include <stdio.h>
#include <pic18f4550.h> // dinh kem thu vien dinh nghia cua PIC18f4550
#include <xc.h>
//turn off watchdog timer, ext crystal without PLL, activate MLCR pin
#pragma config WDT = OFF, PLLDIV = 2, CPUDIV = OSC1_PLL2, FOSC = HS, MCLRE = ON , LVP = OFF
//define crystal frequency for dalay function
#define _XTAL_FREQ 8000000
short int so_dem; // khai bao bien gia tri so dem duoc
float ty_le_cb=0; // ty le cam bien dan
int muc=0; // muc xac dinh cua cam bien
int co_vat=0; // bao co vat can hay khong
short int cham=0xff; // dau cham hien thi tren LED 7 doan bao có vat hay khong
// 0 1 2 3 4 5 6 7 8 9
unsigned char ma7doan[]={0xC0,0xF9,0xA4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned int ADC_Read(unsigned char channel)
if(channel > 7) //Channel range is 0 ~ 7
return 0;
ADCON0 &= 0xC5; //Clearing channel selection bits
ADCON0 |= channel<<3; //Setting channel selection bits
__delay_ms(2); //Acquisition time to charge hold capacitor
GO_nDONE = 1; //Initializes A/D conversion
while(GO_nDONE); //Waiting for conversion to complete
return ((ADRESH<<8)+ADRESL); //Return result
void main(void)
TRISB = 0; //PORTB la output
TRISD = 0; //PORTD la output
LATB = 0;
LATD = 0;
/*TRISC = 1; //PORTD la output
LATB = 1;*/
so_dem = Read_b_eep (0); // doc so dem cu duoc luu trong eeprom tai dia chi 0
ADCON1 = 0x0E; // RA0 is analog, reference voltage is Vdd,Vss
TRISAbits.TRISA0 = 1; // AN0 is input
/*ADCON2bits.ADFM = 1; //right justified
ADCON2bits.ACQT = 2; //ACQT = 4*Tad*/
ADCON2bits.ADCS = 11; //ADCS = Fosc/8, Tad = 1us internal
ADCON0bits.CHS = 0; // select channel 0
ADCON0bits.ADON = 1; //enable ADC
while(1) // vong lap vo han
LATB = (ma7doan[so_dem/10%10]&cham);
LATD = ma7doan[so_dem%10];
__delay_us(25);
ty_le_cb=(ADC_Read(0)*0.39); // doc ty lê % tín hieu tu mat thu hông ngoai (0-100); gia tri adc max=255; 0,39=100/255;
if(ty_le_cb>70) // khi ty le dan cua mat thu lon hon nguong (70) th́ do là muc 1, tuc khong co vat can
muc=1; // xac dinh muc 1;
cham=0xff; // tat LED bao co vat can
if(ty_le_cb<30) // khi ty le dan cua mat thu nho hon nguong (30) th́ do là muc 0, tuc co vat can
muc=0; // xac dinh muc 0;
cham=0x7f; // bat led bao co vat can
co_vat=1; // bao co vat can
if(muc==1&&co_vat==1) // neu muc = 1 và co vat can // tuc vat can da di qua cam bien
co_vat=0; // bao khong co vat
so_dem++; // tang so dem
if(so_dem>99) // gioi han so dem den 99
so_dem=0; // dat lai so dem = 0 khi so dem > 99
Write_b_eep(0, so_dem); // ghi so dem vao EEPROM tai dia chi 0
if(TRISCbits.TRISC2==0) // khi nút reset so dem duoc nhan
while(TRISCbits.TRISC2==0); // tao vong lap chowf nut duoc nha
so_dem=0; // dat so dem ve 0;
if(TRISCbits.TRISC0==0) // khi nut giam duoc nhan
while(TRISCbits.TRISC0==0); // tao vong lap chowf nut duoc nha
so_dem--; // giam gia tri so dem
if(so_dem>99) // neu so dem > 99
so_dem=99; // nap lai so dem = 99
if(TRISCbits.TRISC1==0) // khi nut tang duoc nhan
while(TRISCbits.TRISC1==0); // tao vong lap chowf nut duoc nha
so_dem++; // tang gia tri so dem
so_dem=0; // nap lai so dem = 0
#device ADC = 8 // dat ADC o che do 8 bit
#FUSES HS // su dung thach anh ngoai lam bo giao dông
#use delay(clock = 4000000) // su dung thach anh 20M
int8 so_dem; // khai bao bien gia tri so dem duoc
int8 ty_le_cb; // ty le cam bien dan
int1 muc = 0; // muc xac dinh cua cam bien
int1 co_vat = 0; // bao co vat can hay khong
int8 cham = 0xff; // dau cham hien thi tren LED 7 doan bao có vat hay khong
const char ma7doan[] = { 0xC0,0xF9,0xA4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90 }; //khai bao ma 7 doan tich cuc muc thap ( ki tu 8 bit )
void main() // chuong trinh chinh
so_dem=read_eeprom(0); // doc so dem cu duoc luu trong eeprom tai dia chi 0
setup_adc_ports(AN0); // thiêt lap kenh ADC AN0 lam ngo vao ADC dung de doc tin hieu tu mat thu hong ngoai
setup_adc(ADC_CLOCK_INTERNAL); // thiet lap xung cap cho ADC là xung noi
set_adc_channel(0); // dat kenh cho ADC là kenh 0 (AN0)
while(TRUE) // vong lap vo han
output_b(ma7doan[so_dem/10%10]&cham); // xuât ma LED 7 doan hang chuc ra port B
output_c(ma7doan[so_dem%10]); // xuât ma LED 7 doan hang don vi ra port C
delay_us(25); // tao thoi gian tre us
ty_le_cb=read_adc()*0.39; // doc ty lê % tín hieu tu mat thu hông ngoai (0-100); gia tri adc max=255; 0,39=100/255;
write_eeprom(0, so_dem); // ghi so dem vao EEPROM tai dia chi 0
if(input(pin_d2)==0) // khi nút reset so dem duoc nhan
while(input(pin_d2)==0); // tao vong lap chowf nut duoc nha
if(input(pin_d0)==0) // khi nut giam duoc nhan
while(input(pin_d0)==0); // tao vong lap chowf nut duoc nha
if(input(pin_d1)==0)
while(input(pin_d1)==0); // tao vong lap chowf nut duoc nha
/ CONFIG
#pragma config FOSC = INTOSCIO // Oscillator Selection bits (INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD)
#pragma config BOREN = ON // Brown-out Detect Enable bit (BOD enabled)
#pragma config LVP = OFF // Low-Voltage Programming Enable bit (RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EE Memory Code Protection bit (Data memory code protection off)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
#include <xc.h>
#include <xc.h>
unsigned char led7doan[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7F,0x6F};
unsigned int read_adc_channel(char channel)
unsigned int temp;
ADCON0bits.CHS = channel;
ADCON0bits.GO = 1; // start ADC sampling
while(ADCON0bits.GO == 1);
temp = ADRES;
return temp;
int dv1,c1,i;
void HIENTHI ()
c1 = led7doan[so_dem/10%10];
dv1 = led7doan[so_dem%10];
for(i=0;i<2;i++)
LATD = ~(8 >> i); // chuyen gia tri sang cua led
if(LATDbits.LATD0 == 0){LATB = led7doan[c1];}
if(LATDbits.LATD1 == 0){LATB = led7doan[dv1];}
__delay_ms(4);
unsigned int adc_value;
void main(void)
ADCON1 = 0x0D; // RA0is analog, reference voltage is Vdd,Vss
TRISB = 0; // PORTB la output
LATB = 0;
LATD = 0xFF;
// configure adc
ADCON2bits.ACQT = 2; //ACQT = 4*Tad=4us
ADRES = 0; // clear result registers
// Khai bao gia cac bien
int ty_le_cb=0; // ty le cam bien dan
adc_value = read_adc_channel(0);
ty_le_cb=(adc_value*0.39); // doc ty lê % tín hieu tu mat thu hông ngoai (0-100); gia tri adc max=255; 0,39=100/255;
HIENTHI ();
// nhan cac nut
HIENTHI ();
HIENTHI ();
HIENTHI ();
