Couldn't set the LPC2138 device in Flash 2000 v2.2.3
ramasamy
Member level 1
Hello
I am unable to select the device in Flash 2000 V2.2.3 apllication software,
what coudl be a problem?
silvio
Advanced Member level 3
Romania
Re: LPC2138
You're not able to select it from drop down device list or you're not able to read device ID ?
    ramasamy
ArmDong
Junior Member level 1
Re: LPC2138
it is auto read device ID.
when access to bootloader mode.
ramasamy
Member level 1
Re: LPC2138
I am not able to select device from drop down device list.
I want to know , is it auto read device?
silvio
Romania
Re: LPC2138
You can't do this ?????
ArmDong
Re: LPC2138
you can see in picture and schematic.
1) Press Switch Reset and Switch Load (BSL) of LPC2138 Board for resetting MCU to run. Proceedings of Boot Loader are;
- Press Switch Load (BSL) for a while
- Press Switch Reset while still pressing Load Switch(BSL)
- Let Switch Reset while still pressing Switch Load (BSL)
- Lastly, let Switch Load (BSL) then click OK
2) Connect CPU and there’s detail of Port ID and Boot Loader as in the picture.
