You can find many examples in Mathworks.com site or Mathtools.net. If you have full disk of Matlab sofware, you also find examples in the exam directory of Matlab soffware.
gun55, array signal processing refers both to signal processing of an array of signals as it occurs in a multiple antenna situation, and to the mapping of such algorithms onto parallel hardware platforms. In other words it is a part of signal processing that uses sensors that are organized in arrays, to detect signals and to determine information about them.
From your title "wideband blind beamforming in array processing" i'm guessing you are looking for Matlab code on the application of blind adaptive algorithms using antenna arrays in Wideband CDMA.
@ tsno
There are a lot of tutorials available at www.mathworks.com
Also check out the book "DSP using matlab" by Proakis and Ingle. Its a good text for DSP applications especially for beginners
