jumanji
Newbie level 6
Long story short - I am using a small solid state relay (Clare CPC1017N - see attached) to mimic pressing a switch on another board. The voltage being switched is only 3V and I am sure it is very low current so I am confident that I am within the specs of the relay. They also spec 1mA to turn the relay on and that is almost exactly what I am using. So I send a friend of mine 15 boards and he tests them and tells me none of them work and send them back. Sure enough, the relay has failed on every board. I am trying to figure out where in our process something went so terribly wrong and I keep coming back to him testing them with his meter. It is a cheap Radio Shack meter and he tested them on the resistance mode while making the relay open and close. I don't have much experience using solid state relays so can't say whether they are overly sensitive or not, but is it possible that this meter caused a voltage/current spike big enough to fry the relay? I have never heard of such a thing but I can't think of anything else that would cause this.
If anyone has any insights or experience I would love to hear it - thanks.
View attachment Clare_CPC1017N_SolidStateRelay.pdf
