sweethomela8
Member level 4
To avoid overflow, when you do a multiplication or large sum, you have enough bits to hold the largest value possible from the arithmetic. If you need to scale down in bits, do you take the number of bits from the MSB downto the number of bits you can use? say you have a 20 bit sum and need to truncate it down to 10 bits...do you take the MSB down to the 10th bit?
