Hello,
We are wanting to use the IRF6674 metal topped SMT FET in our 15W buck converter. The heatsink is above the PCB so we need to put “gap-pad” in between the FET and the heatsink.
However, the Metal Top of this FET is connected to the drain of the FET. Therefore, we will need to cover the metal top of this FET with insulating “sil-pad” sheet before we apply the gap-pad.
Supposing instead we had used a plastic topped FET such as the RJK0651 (datasheet below), then we are thinking we would then not need to use the sil-pad under the gap-pad. However, the RJK0651 , being plastic topped, would need us to then additionally gap-pad the PCB copper that connects to this FET, to the heatsink…..and that copper is at drain node potential in places…..so once again, we would need to cover that PCB copper in sil-pad before gap-padding it to the heatsink.
Can you think of any way round this, such that we could gap-pad the hot transistor to the above-PCB heatsink, without needing to use insulating sil-pad. After all, the sil-pad application will be fiddley and the assemblers may forget to apply it.
IRF6674 Metal topped SMT FET datasheet:-
https://www.infineon.com/dgdl/irf6674pbf.pdf?fileId=5546d462533600a4015355ec9f0d1a66
RJK0651 datasheet (plastic topped SMT FET)
Thin Insulating sheet (sil-pad)
https://www.bergquistcompany.com/thermal_materials/sil-pad.htm
Gap-pad (medium for conducting heat to heatsink from semiconductor)
https://www.bergquistcompany.com/thermal_materials/gap-pad.htm
