converting dBuV to dBm for ETSI standards
yashiro32
Member level 1
dbuv to dbm
is there any special formulas or calculations to convert dBuV to dBm for ETSI standards.
convert dbuv/m to dbm
Is there any difference in the calculations between the measurements taken in a 3m chamber and a 10m chamber ?
dbuv to dbm conversion
There may be slight differences, but suppose to be same if the IFFT and other calculations , calibrations are proper and correct.
The main difference I knew is based on the antenna size the chamber will be selected.
Let say if you have an array of 1024 elements then even 10 meter chamber is not sufficient.
dbuv m to dbm conversion
Please be careful when translating units.
uV to mW (or dBuV to dBm) is straightforward (you only need to know the reference impedance which is most commonly 50Ohms) and no distance comes into play, but I guess you are actually referring to electric field strength dBuV/m. In this case, convert dBuV/m first to V/m (by taking 10^(dBuVm/20) and compensate for uV-V) and then use P/(4*pi*r^2)=E^2/377
dbm to dbuv conversion
dBm to dBuV =
dBm + 138.75 = dBuV
dbuv dbm
dBuV is referring to loaded output voltage rather than emf, thus the translation is 107 dBuV = 1 dBm with 50 ohms matching!!!
dbm dbuv
sorry for the late reply, thanks for all your help .
