Terminator3
Advanced Member level 3
Hello again!
After calculating antenna factor, it can be converted to dB 20*log10(AntennaFactor(phi,theta))]),
wher theta - angle -90..+90 deg. phi = 0 or 90 deg.
Next step is to draw radiation pattern in dB:
https://www.antenna-theory.com/arrays/arrayfactor.php
I am unsure about that multiplication must be done with radiation pattern or normalized radiation pattern?then the radiation (or reception) pattern for an antenna array is simply the Array Factor multiplied by the radiation pattern
