MathieuChalnot
Newbie
Hello everyone,
Suppose you have an antenna with a narrow pencil-beam radiation pattern pointing broadside.
Well, at least you designed the antenna to behave that way.
Then, when you measure its radiation pattern, instead of having a maximum at 0° (for example), you notice that the maximum is at 3°.
How can you determine whether this error comes from improper positioning of the antenna inside the anechoic chamber or from the antenna design itself?
Thank you very much in advance.
