Convert fractional number to hardware
stevepre
Member level 4
Member level 4
Is there any tools or anybody has a script or program that can quickly convert a fractional number to hardware representation?
For example: (simple one that people can usually calculate it by inspection)
0.5 = 0.1
0.25 = 0.01
-0.5 = 1.1
-0.25 = 1.11
-0.0001234 = ?????
And it gets more complicated if there is interger number combined, like 123.456
Is there a program or a script which can do that?
Thanks
as for your criteria: the follow perl script can do the 16 bit fix point fractional number representation:
"-1<=x<1, the first bit is the signed bit, the remaining 15 bit are fraction part"
open SRC, "data";
while (<SRC>) {
chomp($_);
$_=$_*(2**15);
printf DST "%b,", $_;
thanks Jackson_peng.
However, there's problem with your script when dealing with negative numbers. It always prints out full 32 chars....
Any solution?
Checkout this just stripped off lower 16 bits from 32 bits
open SRC, "data";
while (<SRC>) {
    chomp($_);
    print "n = ".$_." " ;
    $_=$_*(2**15);
    $t = sprintf( "%0.16b", $_);
    @k = split(//,$t);
    for ($i=0; $i < 16; $i++) {
        print $k[$i];
    print "\n";
Result:
n = 0.5 0100000000000000
n = 0.25 0010000000000000
n = 0.125 0001000000000000
n = 0.1234 0000111111001011
n = -0.5 1111111111111111
n = -0.25 1111111111111111
n = -0.125 1111111111111111
n = -0.1234 1111111111111111
still...negative number is still the main problem
