convert double to char array
ernytony
Newbie level 6
is possible convert double to char array
You did not mention which compiler and processor you are using.
On an 8 bit processor something like this should work:
union
double doub;
char chars[4];
}help;
Now help.doub would adress your double value and help.chars[0] to help.chars[3] would adress the same as single chars.
Hope this does what you want to do.
best regards
sorry I use Pic 16f877 & picclite
Then my above post should be ok for you ...
best regards
