convert c code from TI CCS to c
lgeorge123
Full Member level 2
Full Member level 2
Hong Kong
I have a c code from TI CCS as follows:
float Ic;
lc=(float) (AIC23_data.channel
it convert LEFT channel of ADC to float number , how can I do this in like Convert function ( C format )other than TI CCS such as
float Ic;
byte Adcvalue = { 1,1,1,0,0,1,1,0}; // from 8 bit ADC value
float Convert(byte value);
Ic (float) = Convert(Adcvalue);​
Hello!
Just to make things clear, there is no TI CCS C and other C, there is C, period.
Now converting to float is done by a plain cast, but apparently you know that.
Cast is pretty standard and should work with any compiler.
Now one thing: why do you want to use float numbers? Usually it's a lot slower
to calculate with floats than with integers, then another issue is that converting
to float a value that has a very limited set of possible values (4096 if you use
TI processors) is a bit surprising.
Dora.
