Convert binary (integer and a fraction) from vhdl to decimal in C code, negative value
wannaknow
Junior Member level 2
Convert binary ( integer and fraction) from vhdl to decimal in C code,negative value
HI,
I have a 14-bit data that is fed from FPGA in vhdl, The NIos II processor reads the 14-bit data from FPGA and do some processing tasks, where Nios II system is programmed in C code
The 14-bit data can be positive, zero or negative. In Altera compiler, I can only define the data to be 8,16 or 32. So I define this to be 16 bit data.
First, I need to check if the data is negative, if it is negative, I need to pad the first two MSB to be bit '1' so the system detects it as negative value instead of positive value.
Second, I need to compute the real value of this binary representation into a decimal value of BOTH integer and fraction.
I learned from this link (https://stackoverflow.com/questions...ary-floating-point-1101-11-into-decimal-13-75) that I could convert a binary (consists of both integer and fraction) to decimal values.
I am wondering if this code can be used to check for negative value? I did try with a binary string of 11111101.11 and it gives the output of 253.75...
I have two questions:
What are the modifications I need to do in order to read a negative value?
I know that I can do the bit shift (as below) to check if the msb is 1, if it is 1, I know it is negative value...
if (14bit_data & 0x2000) //if true, it is negative value
The issue is, since it involves fraction part (but not only integer), it confused me a bit if the method still works...
If the binary number is originally not in string format, is there any way I could convert it to string? The binary number is originally fed from a fpga block say, 14 bits, with msb as the sign bit, the following 6 bits are the magnitude for integer and the last 6 bits are the magnitude for fractional part.
Any idea please? Thank you in advance
How to read a 16-bit data into string in C code
I have a 16-bit data that is fed from FPGA in vhdl, the NIos II processor reads the 16-bit data from FPGA and do some processing tasks, where Nios II system is programmed in C code
How could I read this 16-bit data in string?
printf("%d", 16_bit_data);
    // it shows a decimal value of 15282
What should I do in order to get the result displayed as a string 0011101110110010?
Thank you in advance.
Re: How to read a 16-bit data into string in C code
Translate to hex (sprintf("%04x",v)) and then translate each hex digit to binary, or use something like the function
_showbin() in post #5 from this thread https://www.edaboard.com/threads/338259/#post1443173
Thanks for your reply, forgive me for didnt make it clear enough.
I need to compute the real value of this binary representation into a decimal value of BOTH integer and fraction, for example, the value is 15282 (0011 1011 1011 0010), but it is not the real value, how to make sure I will get the value as -30.750015?
The 14-bit-data is defined as follow: with msb as the sign bit, the following 6 bits are the magnitude for integer and the last 6 bits are the magnitude for fractional part.
