Conversion of LabVIEW code to Embedded C
kaus9952083382
Member level 4
Member level 4
Is it possible to convert LabVIEW code to embedded C.I want to use it in burning the program in 8051 microcontroller.....
Labview, its a graphical represent / user interface based method , so if you look at its code you easily rewrite the code in Embedded C, where in as you have to configure set of registers to work accordingly !
But to my knowledge there aren't any compilers which can convert such a way.
