Jul 28, 2006 #1 0 020170 Full Member level 4 Joined Jan 31, 2005 Messages 231 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 2,221 When I simulation only one latch circuit, I have no converge problem and I can get reasonable result. But I simulated many latch circuits by using hspice, I often don't get any result because of converge problem. Sometimes, simulation is working properly, amazingly. but resulting waveform is weird. Is there any one who have same problem like me? How can I solve this problem? thanks.
Jul 30, 2006 #2 N nuiscet Member level 2 Joined Sep 13, 2005 Messages 53 Helped 3 Reputation 6 Reaction score 0 Trophy points 1,286 Activity points 1,684 sometimes we can try to use a pwl input wave to solve the converge problem , maybe. for example, v0 vdd 0 pwl 0 0 1u 3.0
Jul 30, 2006 #3 E ericliu Member level 1 Joined Dec 31, 1999 Messages 39 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 153 To solve the DC converge problem in latch circuits , use command "noseset" to set one of the cross-couple nodes to power or ground.
Aug 1, 2006 #4 D desperado0729 Newbie level 6 Joined May 27, 2006 Messages 12 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,283 Activity points 1,348 You need to give an initial condition for the output node. Ex. .ic V(out)=0
Aug 1, 2006 #5 S stoned Member level 3 Joined Feb 23, 2006 Messages 55 Helped 7 Reputation 14 Reaction score 2 Trophy points 1,288 Activity points 1,606 using PWL source can solve, because ur latch's inital is uncertainty, hspice can't find the converge solution stoned best regards
Aug 3, 2006 #6 E engrvip Full Member level 2 Joined May 3, 2006 Messages 142 Helped 3 Reputation 6 Reaction score 0 Trophy points 1,296 Activity points 2,377 most probablt PWL signal will spve ur prob. othrwise try to play with abstol reltol values
