T
treez
Supposing i have a horizontal E42/21/15 bobbin as on page 5 of the following....
Assume its 10 pins number like an IC
Often you get winding specs annotated by saying "all windings wound clockwise round the former".
What does this mean?
Supposing you have a primary connected from start pin 3 to pin 4
And a secondary connected from start pin 9 to pin 10.
Do you take "clockwise" as being as if you are looking at the row of primary or secondary pins depending on which coil you are winding?.....or do you take it that "clockwise" always means looking at the "Pins 1 to 5" side?
Do winding companys have any convention here?
Wouldnt it just be better to give a coil cross section diagram and show which end is the "dot" end?
