flote21
Advanced Member level 1
Hi guys!
I need to delay the power off sequence of two sw regulator. Normally it is relatively easy to control the power up sequence through the enable pin, however the power off, how can assure that on one of the sw regulator is "alive" more time than the other? Se below the required power down sequence:
I have been thinkin to delay the ouput +0V9 volt with a PMOS transitor and a RC connected to the gate but I want to know if there are other options...
thanks in advance.
Greetings.
thanks in advance.
Greetings.
