lins13
Hi Guys,
I have a signal which I must use as a control signal for a DAC. However the device the control signal comes from holds the signal at -3.3V for a low and +3.3V for a high. This cannot be changed. I need the signal to sit at 3.3V high normally and pulse to 0v for a low.
Essentially I have a signal that sits at -3.3V usually and pulses to +3.3V and I want this to sit at +3.3V and pulse low to 0V
I will need an inversion, i.e. some kind of NOT gate, but I am unsure what device can be used to change the signal levels
Any suggestions?
Thanks
Any suggestions?
Thanks
