is it possible to write a fdtd code for t stub of a continuous transverse stub antenna array ??
thanks a lot 4 ur information .
Aim is to numerical analysis of coaxial continuous transverse stub antanna array for w-band applications using fdtd code and derive t field equations & simulation .
in t cts antenna array , is any one can help on how to find the generation of grid cells for the cylindrical waveguide ....... ? .. i had referred t yee lattice algorithm 4 cartesian coordinate system, but no idea for this stub ..........
how to derive t field equations & simulate it using fdtd method ??????
Being an unpaid private consultant is not really what I want to spend my time on, but I don't mind answering questions on the forum.
Before going any further you would have to
1) state what you actually know about FDTD (what books/papers did you read)
2) describe the model (the physical details: materials, geometry)
i referring computational electromagnetics by TAFLOVE ..
the model to be analysed is a cylindrical stub of radius= 8.4mm , thickness=0.8mm , material = brass
