contact resistance vs Vgs formulation
electronicman26
Full Member level 2
hello
I want to draw contact resistance variation against the Vgs voltage of Organic fet, but I don't know the equation that I can use to plot
electronicman26
Full Member level 2
cant anyone help me or reference me to a paper or link?
dick_freebird
Advanced Member level 5
USA
To me this seems like a malformed question.
A FET of any sort has contact resistances in series with
the channel conductance (resistance). Contact resistance
itself ought not respond to gate voltage, it is remote from
the gate and not under its influence. Channel "hookup" to
source, that's another and important deal but is not about
the resistance of a contact feature - has to do with the
engineered spacer and whether it stands off the source
side-diffusion too far, requiring extra channel bias to extend
the channel laterally until it connects to the heavily doped
access region.
This latter, you can see as a Rds(on) at low Vds nonlinearity
as you pass through zero. A well formed MOSFET will look
linear through the origin, a poorly connected one will have
a high Rds(on) below (say) 100mV Vds, which can be
distinguished from the /0 singularity by its breadth-of-region
and curvedness.
It would probablt take specialized structures to separate the
contact, access and channel resistancr contributions - PCM
structures probably have contact and channel, leaving the
access resistance as a de-embed problem?
timof
Advanced Member level 3
San Jose, CA, USA
I think the key to understand the background of this questions is this - "organic FET".
It looks like organic FETs have quite different physics than standard Si MOSFETs - see for example this paper:
https://scitation.aip.org/content/aip/journal/apl/97/26/10.1063/1.3533020
In particular, contacts in organic FETs are not Ohmic, and their properties depend on channel condition (applied voltages, etc.).
electronicman26
Full Member level 2
yes, I see this paper and other papers like this, but the papers just present the variation of contact resistance vs gate-source voltage in Fig and dont present any equation, Is it possible for me to have a math equation between Rc and Vgs ??
timof
San Jose, CA, USA
