Constraints for Clock gating a complete module
rakeshmglth
Newbie level 1
Newbie level 1
Dear all,
I am trying to perform clock gating for a submodule present in a bigger design. I want to disable/enable the clock to this submodule depending on a control register. The module I want to clock gate is MB as shown in the attached figure.
I implement this is verilog using and AND gate as shown and synthesize using Synopsys design compiler. Note that I do not want to use compile_ultra -gate_clock command as I do not want to clock gate any other modules in the whole design.
The problem arises when running with the sdf that I generate. The tool generates a huge delay for the ouput of the and gate as shown in the sdf snippet below.
(CELL
(CELLTYPE "CELL_FROM_LIB")
(INSTANCE interp_clk_gate_inst/U3)
(DELAY
(ABSOLUTE
(COND !B (IOPATH A Z (19412.504:19412.631:19412.631) (5637.378:5637.325:5637.325)))
(COND A (IOPATH B Z (19473.148:19473.148:19473.148) (5625.532:5625.532:5625.532)))
The constraints I am using are shown below.
create_clock -period ${CLOCK_PERIOD} [get_ports clk]
set_drive 0 {clk}
#set_propagated_clock [all_clocks]
#add around 5% uncertainty
set_clock_uncertainty 0.4 clk
set_dont_touch_network {clk}
create_generated_clock -name interp_gated_clk -source [get_ports {clk}] -divide_by 1 [get_pins interp_clk_gate_inst/gclk]
update_timing
set_clock_gating_check -setup 0.15 -hold 0.03 interp_gated_clk
update_timing
set_propagated_clock interp_gated_clk
set_false_path -from [get_ports rst]
Is there a specific way to tell the tool to buffer more if needed to fix this huge delay?
Thanks in advance.
Rakesh
