Constant Voltage Transformer:Finding Number of turns
Cybot
Newbie level 2
Newbie level 2
Hi to all , First time here.Sorry if posted in wrong section.
across Primary 230V 50Hz input
At secondary:
capacitor 36 µF and 60vrms (root mean square) across capacitor
Load :
66 ohm
.71A
51V
secondary o/p = 78v rms
PF should be 1.
Input and output should be same.
Need to find: Wire gauge,Number of turns across primary and secondary.
I have referred few Paper regarding CVT but
Constant Voltage transformer or CVT use a tank circuit composed of a high-voltage resonant winding and a capacitor to produce a nearly constant average output with a varying input.
Kindly Help me to solve this.I have basics knowledge physics and Engineering maths.
I'm BE Computer guy.
Thank you.
A constant voltage transformer has a special design, stray field transformer with saturated secondary core halve. I don't see how you would calculate it without the magnetical data?
Reactions: Cybot
    Cybot
I am using type LAMINATION TYPE 30 ....Lamination is made in CRNGO,,stack size 1.25inch
Windows size =70mm
Used shunt = 5 mm
