laskin
Newbie level 2
- Joined
- May 3, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 23
Hi everybody, I am relatively new to DSP and completely new to this forum, as you can see. I am a masters student in neuroscience and am in the process of collecting electrophysiological data from the rat brain. In the brain there certainly is oscillatory activity which is periodic, but there also is activity which is aperiodic. I'm currently designing Matlab scripts to analyze my data and am using the fast Fourier transform for constructing periodograms and similar things. My question is, would this be adequate if the signal was aperiodic? I guess then I should use a DTFT analysis instead. What kinds of errors would I make if I analyze a signal which is aperiodic as if it were periodic? What about treating a periodic signal as aperiodic?
Thank you in advance for your help!
