skn96
Junior Member level 3
Connector from battery to pcb
Hi All
I am designing a grid tied battery powered inverter where the input battery voltage is 48 volt and the max input current from the battery in steady state can go to as high as 105 Amp (4800 Watt inverter). That means for the input terminal connectors from battery to pcb I can not use ordinary connectors. I was told to use copper bus bars to connect battery to pcb and to solder the bas bar on the pcb board(pcb is 6 layers 2oz copper). Now the question is where I can get these bus bars? Are there any standard bus bar parts? I prefer not to order customized parts due to the cost. If I have to order customized bus bar then what companies I can refer to? How can I solder these wide thick bus bar on the pcb board? If we want to have mass production is the soldering machine capable of soldering bus bar on the board ? Any other suggestion other than using bus bar?
Thanks in advance
Hi All
Thanks in advance
