Connections needed...pls help..
nirmal_rockin
Junior Member level 2
India
Can anyone pls tell the internal connections of this isp header... i'm confused about the ground connections...r the miso. sck, rst, and mosi grounded????
pls help thanks
ark5230
Advanced Member level 3
India
May be the ground pin you are looking for is the pin No 10 black square in the figure (right bottom on the connector view shown)
nirmal_rockin
India
s but i'm asking whether the miso, sck,mosi ,rst pins are also grounded....wat is the need of 4 ground connections....
(Actually i need the isp header connections for and avr programmer board which i'm building)...
P
pauloynski
This is a 2 rows (2x5) connector. Just all the unused pins were grounded.You need not to use them. Use only the one in black if you want.
ark5230
India
As rightly pointed out by pauloynski, you can use one ground. If you see the connector, may be all grounds are not wired. Use the one that is wired and the balck one is.
Raoof
