sirricky
Newbie level 6
Hello everyone,
1. since the ground plane of microstrip line is in different layer with the center line, assuming the CPW line is in layer 1, the center line of microstip is also in layer1, and the ground of microstrip line is in layer2, how could I set the ports?
on the CPW side, I set as -1,1,-1 (GSG), but on the microstrip line side, how do I set the port? do I need to connect the differnet Gound line by vias?
2. I want to simulate the unload Q of a half wavelength microstrip line as a resonator in Sonnet. assuming the end is open. I do in this way:
set port 1 on one side of line, and in order to make the other side open, I leave a gap to the edge of the box. Then plot S11.
Is it ok?
Is it ok?
