Good day, Everyone
I am using ADS Keysight in the design of my schematic and the layout of a circuit. However, I am encountering a problem. I do not know how to select an appropriate wire for each terminal.
Foe example, I am using a CBEBC npn configuration with 3 terminals, numbered 1,2 and 3 for collector, base and emitter respectively.
My questions are as follows:
1. Must i connect to the terminals listed above or the body of the collector, base and emitter?.
2. Should i use the default line provided by ADS when connecting to either terminal or body?
3. If i must use a different line, how do I go about selecting the appropriate one?.
4. Is the terminal connecting to the substrate not important as i can only find 3 terminals instead of 4 seen in the schematic?.
Thank you.
