CONNECTING SRAM , CAMERA MODULE , PIC AND FPGA
JacquesKleynhans
Member level 2
Hi Guys I have been developing code for better part of the last couple of months as well I only learned VHDL in the last couple of months to connect a omnivision 0v5620 to fpga controlled by a pic (for the sccb of the camera) and connected to sram.
I have basically tried everything but my code does not work or at least not work correctly. Please Please can some one help me.....
Please guys I know Its a lot of code, but can some please check it out please. Think the issue might be in the data flow section.
Here it goes
Top file responsible for counting incoming rows to crop image size , set control lines to sram and include all components.
-- camera_payload.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity camera_payload is
	port    (
				main_clk		:	in std_logic;
				main_reset		:	in std_logic;
				-- DATA FROM CAMERA TO SRAM
				cam_data  		:	in std_logic_vector (7 downto 0);		-- data from camera
				memory_inout	:	inout std_logic_vector (7 downto 0);	-- data to and from ram
				data_out		:	out std_logic_vector (7 downto 0);		-- data to pic
				--GENERAL CONTROL LOGIC
				enable			:	in std_logic;							-- enable operation bit
				read_write		:	in std_logic;							-- read\not write
				ack				:	out std_logic;							-- acknowledge bit
				read_clk		:	in std_logic;							-- enables read clk
				--SRAM
				--ADDRESS
				address_out		:	out std_logic_vector (21 downto 0);		-- adress of ram
				--LOGIC SIGNALS
				sram_we			:	out std_logic;
				sram_oe			:	out std_logic;
				sram_cs1		:	out std_logic;
				sram_cs2		:	out std_logic;
				sram_byte		:	out std_logic;
				sram_lb			:	out std_logic;
				sram_ub			:	out std_logic;
				--CAMERA
				cam_href		:	in std_logic							-- href from camera
-				cam_pclk		:	in std_logic;							-- pclk from camera
--				cam_vsync		:	in std_logic;							-- vsync from camera
				cam_xvclk		:	out std_logic							-- xvclk to camera
end camera_payload;
architecture behavior of camera_payload is
	-- attribute syn_preserve : boolean;
	-- attribute syn_preserve of behavior: architecture is true;
signal write_adr				:	std_logic_vector(21 downto 0);
signal read_adr					:	std_logic_vector(21 downto 0);
signal pll_lock					:	std_logic;
signal global_reset				:	std_logic;
signal state_enable				:	std_logic;
signal count_rows 				: 	std_logic_vector (10 DOWNTO 0) := "11111111111";
signal cam_data					:	std_logic_vector(7 downto 0);
signal pixel_clk				:	std_logic;
signal write_count 				:std_logic_vector(7 downto 0) := "00000000";
component dataflow_control is
	port
		(	state_enable	: in    std_logic;
			output_enable	: in    std_logic;
			camera_clk	: in    std_logic;
			readclk		: in    std_logic;--***************************************
			data_in		: in    std_logic_vector(7 downto 0);
			data_out		: out   std_logic_vector(7 downto 0);
			data_inout	: inout std_logic_vector(7 downto 0)
end component ;
component adress_select is
	port (	write_adr		:	in std_logic_vector (21 downto 0);	-- write address gen
			read_adr		:	in std_logic_vector (21 downto 0);	-- read address gen
--			enable			:	in std_logic;						-- enable module
			read_write		:	in std_logic;						-- write or read
			sram_adr_out	:	out std_logic_vector (21 downto 0)	-- address to sram
end component;
component address_write is
	port (  main_reset	:	in std_logic;						-- main reset
			cam_pclk	:	in std_logic;						-- pixel clock
			cam_href	:	in std_logic;						-- new line acknowledge
			read_write	:	in std_logic;						-- read \ not write
			write_adr	:	out std_logic_vector (21 downto 0));-- adress to RAM
end component;
component address_read is
			read_clk	:	in std_logic;						-- pic clock
			read_adr	:	out std_logic_vector (21 downto 0));-- adress to RAM
end component;
component payload_pll is
port(powerdown : in std_logic;
clka : in std_logic;
lock, gla : out std_logic);
end component;
BEGIN
stage0: dataflow_control port map (state_enable,read_write,pixel_clk,read_clk,cam_data,data_out,memory_inout);
stage1: address_write port map (main_reset,enable,pixel_clk,cam_href,read_write,write_adr);
stage2: address_read port map (main_reset,enable,read_clk,read_write,read_adr);
stage3: adress_select port map (write_adr,read_adr,read_write,address_out); --removed ,state_enable
stagepll: payload_pll port map( '1', main_clk, pll_lock, pixel_clk);
process (pll_lock,main_reset)
begin
global_reset <= pll_lock and main_reset;
end process;
-- THIS PROCESS I USE FOR TESTING INPUT
process(pixel_clk, global_reset, enable)
begin
	if (global_reset = '1') then
		write_count <= "00000000";
	elsif rising_edge(pixel_clk) then
		if enable = '1' then
			write_count <= std_logic_vector(unsigned(write_count) + 1);
		else
		end if;
	end if;
end process;
		 cam_data <= write_count;
process(cam_href,read_write,enable,main_reset)
	begin
		if main_reset = '1' then
			count_rows <= "11111111111";
			ack         <= '0';
		elsif rising_edge (cam_href) then
				if	read_write = '0' and enable = '1' then
					count_rows <= std_logic_vector(unsigned(count_rows) + 1);
					if count_rows = "11000000000" then
						ack <= '1';
					end if;
				end if;
		end if;
end process;
process (enable,read_write)
	begin
		if (enable = '1') then
			state_enable    <= '1';
				if (read_write ='0') then
					sram_oe		<= '0';
					sram_we		<= '0';
					sram_cs1	<= '0';
					sram_cs2	<= '1';
					sram_byte	<= '0';
					sram_lb		<= '0';
					sram_ub		<= '0';
				elsif (read_write = '1') then
					sram_oe		<= '0';
					sram_we		<= '1';
					sram_cs1	<= '0';
					sram_cs2	<= '1';
					sram_byte	<= '0';
					sram_lb		<= '0';
					sram_ub		<= '0';
				end if;
		else
			state_enable    <= '0';
			sram_oe		<= '1';
			sram_we		<= '1';
			sram_cs1	<= '0';
			sram_cs2	<= '1';
			sram_byte	<= '0';
			sram_lb		<= '0';
			sram_ub		<= '0';
		end if;
	end process;
END behavior;
This Component is responsible for tri stating my input and output for flow controll to and from the sram I think this might be the culprit but not sure.
library ieee;
entity dataflow_control is
port
	data_inout	: inout std_logic_vector(7 downto 0);
end dataflow_control;
architecture behavior of dataflow_control is
signal data_in_reg	:std_logic_vector(7 downto 0);
signal data_out_reg	:std_logic_vector(7 downto 0);
begin
	process(camera_clk,state_enable,data_in)
		begin
		if (state_enable = '1' and rising_edge(camera_clk)) then
				data_in_reg <= data_in;
		end if;
	end process;
	process(readclk,state_enable,data_out_reg)
		begin
		if (state_enable = '1' and rising_edge(readclk)) then
				data_out <= data_out_reg;
		end if;
	end process;
	process(output_enable,data_inout,data_in_reg)
		begin
			if output_enable = '1' then
				data_inout <= "ZZZZZZZZ";
				data_out_reg <= data_inout;
			else
				data_inout <= data_in_reg;
			end if;
	end process;
end behavior;
The last three components are responsible for generating the read address and
write address and also select witch address is send to the output of the sram.
-- address_read.vhdlibrary ieee;
library ieee;
entity address_read is
	port (  main_reset	:	in std_logic;							--main reset
			read_adr	:	out std_logic_vector (21 downto 0));    -- adress to RAM
end address_read;
architecture behavior of address_read is
signal adr_cntr_read : std_logic_vector (21 downto 0) := "0000000000000000000000";
begin
process (main_reset, read_write,enable,read_clk)
	begin
			adr_cntr_read <= "0000000000000000000000";
		elsif rising_edge(read_clk) then
			if enable = '1' and read_write = '1' then
				adr_cntr_read <= std_logic_vector(unsigned(adr_cntr_read) + 1);
			else
				end if;
			end if;
	end process;
	--OUTPUT ASSIGNMENTS
		read_adr <= adr_cntr_read;
end behavior;
-- address_write.vhd
--address will; be generated on the rising edge of cam_pclk when cam_href is 1, write is selected and module enabled
library ieee;
entity address_write is
			write_adr	:	out std_logic_vector (21 downto 0));-- adress to RAM					-- main reset
end address_write;
architecture behavior of address_write is
signal adr_cntr_write : std_logic_vector (21 downto 0) := "0000000000000000000000";
begin
process (main_reset,enable,cam_href,read_write,cam_pclk)
begin
		adr_cntr_write <= "0000000000000000000000";
	elsif rising_edge(cam_pclk) then
		if cam_href = '1' and enable = '1' and read_write = '0' then
			if enable = '0' then
			else
			adr_cntr_write <= std_logic_vector(unsigned(adr_cntr_write) + 1);
			end if;
		end if;
	end if;
end process;
	-- OUTPUTS ASSIGNMENTS
		write_adr <= adr_cntr_write;
end behavior;
-- adress_select.vhd
library ieee;
entity adress_select is
		); -- adress send to RAM
end adress_select;
architecture behavior of adress_select is
begin
sram_adr_out <= write_adr when (read_write = '0') else read_adr when (read_write = '1');
 end behavior;
Kindest Regards
JAcques
Can you tell me what is the exact problem? What kind of error you are getting? Have you synthesized it? Which device you are using?(Actel or Xilinx)
HI Thx for replying,
I am having a problem with the bidirectional bus for the sram I have implemented.
I am using an actel device with synplify pro. When I load the vhdl code onto the fpga, and measure at the sram signals with my logic analyser I see the logic moving for my write section of the code but when i enable the signals for a read the the addr increments but its like there is a bus conflict on the output port.
I have changed my bidirectional code a bit since I loaded the code seen in the top of the post.
I have simulated it pre synth then it works fine as shown in the presynth, but a conflict appears in the post synth simulation.
I get these errors:
Updated bidirectional code:
library ieee;
port
	camera_clk	: in    std_logic; 				-- write clk
	data_output	: out   std_logic_vector(7 downto 0)
signal data_inout_reg	: std_logic_vector(7 downto 0);
signal data_output_reg	: std_logic_vector(7 downto 0);
begin
	--MODIF (write)
	process(main_reset, camera_clk)
		begin
		if (main_reset='1') then
			data_inout_reg <= (others => '0');
		elsif rising_edge(camera_clk) then
			if (state_enable = '1' and output_enable = '0') then
					data_inout_reg <= data_in;
			else
					data_inout_reg <= "ZZZZZZZZ";
			end if;
		end if;
	end process;
	data_inout <= data_inout_reg;
	process(main_reset, readclk)
		begin
			data_output_reg <= (others => '0');
		elsif rising_edge(readclk) then
			if (state_enable = '1' and output_enable = '1') then
				data_output_reg <= data_inout;
			else
				data_output_reg <= "ZZZZZZZZ";
			end if;
		end if;
	end process;
	data_output <= data_output_reg;
end behavior;
I have also checked my net list to see if there are irregular hardware assignment although i am very net to checking the net-list but they seem fine to me, buffer placements are correct, tristate and bi directional are also correct.
Can I be synthesizing the the vhdl wrong then compiling wrong data ??
