LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.NUMERIC_STD.all;
ENTITY SPI_MASTER IS
GENERIC
NUM : INTEGER := 24
PORT
CLK_IN : IN STD_LOGIC;
SPI_MASTER_SDIO : INOUT STD_LOGIC;
SPI_MASTER_CLK : OUT STD_LOGIC;
SPI_MASTER_CS : OUT STD_LOGIC;
ADC_DATA_IN : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END ENTITY;
ARCHITECTURE BEHAV OF SPI_MASTER IS
CONSTANT ADC_WRITE_REG : STD_LOGIC_VECTOR(12 DOWNTO 0) := '0' & x"008"; --WRITE REGISTER
CONSTANT ADC_DATA : STD_LOGIC_VECTOR(7 DOWNTO 0) := x"10"; --DATA TO WRITE
CONSTANT ADC_READ_REG : STD_LOGIC_VECTOR(12 DOWNTO 0) := '0' & x"015"; --READ REGISTER
SIGNAL DATA_TO_ADC : STD_LOGIC_VECTOR(NUM-1 DOWNTO 0) := '0' & "00" & ADC_WRITE_REG & ADC_DATA;
SIGNAL DATA_FROM_ADC : STD_LOGIC_VECTOR(15 DOWNTO 0) := '1' & "00" & ADC_READ_REG;
SIGNAL OE : STD_LOGIC := '1'; --OUTPUT ENABLE FROM FPGA, WHEN HIGH: SEND DATA TO ADC, WHEN LOW: RECEIVE DATA FROM ADC
SIGNAL DATA_IN : STD_LOGIC_VECTOR(7 DOWNTO 0) := "11111111";
SIGNAL MASTER_RST : STD_LOGIC := '0';
SIGNAL SENT : INTEGER := 0; --NUM BITS SENT
SIGNAL RCVD : INTEGER := 0; --NUM BITS RECEIVED
SIGNAL ADC_CLK : STD_LOGIC := '0'; --SERIAL CLOCK FOR ADC
SIGNAL COUNT : INTEGER := 0;
BEGIN
PROCESS(CLK_IN)
BEGIN
IF(RISING_EDGE(CLK_IN)) THEN
IF(COUNT = 2) THEN
ADC_CLK <= NOT ADC_CLK;
COUNT <= 0;
ELSE
COUNT <= COUNT + 1;
END IF;
END IF;
END PROCESS;
PROCESS(ADC_CLK,MASTER_RST,OE)
BEGIN
IF(FALLING_EDGE(ADC_CLK) AND MASTER_RST = '0') THEN
IF(OE = '1') THEN
IF(SENT < 23) THEN
--DATA_FROM_ADC <= DATA_FROM_ADC(14 DOWNTO 0) & '1';
DATA_TO_ADC <= DATA_TO_ADC(22 DOWNTO 0) & '1';
SENT <= SENT + 1;
ELSE
OE <= '0';
END IF;
END IF;
ELSIF(RISING_EDGE(ADC_CLK) AND MASTER_RST = '0') THEN
IF(OE = '0') THEN
DATA_IN <= DATA_IN(6 DOWNTO 0) & SPI_MASTER_SDIO;
RCVD <= RCVD + 1;
IF(RCVD > 6) THEN
MASTER_RST <= '1';
END IF;
END IF;
END IF;
END PROCESS;
--SPI_MASTER_SDIO <= DATA_FROM_ADC(15) WHEN OE = '1' ELSE 'Z';
SPI_MASTER_CS <= '0';
SPI_MASTER_CLK <= ADC_CLK;
ADC_DATA_IN <= DATA_IN;
SPI_MASTER_SDIO <= DATA_TO_ADC(23) WHEN OE = '1' ELSE 'Z';
END BEHAV;
