conditional assignment statement
sree205
Advanced Member level 1
can we use the conditional assignment statement inside always blocks like the example below ??
module ex(clk,x,a,b,y)
input a,b,x;
output y;
reg y;
always@(posedge clk)
y = x ? a : b ;
endmodule
It wrote not correctly!!!
assign in always not use!!!!
need write:
OR
assign y = x ? a : b ;
OR
if (x)
y = a;
else
y = b ;
OR
case (x)
1'b1 : y = a;
1'b0 : y = b ;
endcase
input a,b,x;
output y;
reg y;
y = x ? a : b ;
endmodule
That should work. Did you see any issues?
Ajeetha, CVC
Contemporary Verification Consultants Pvt Ltd. http://www.noveldv.com
* A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5 http://www.systemverilog.us/
* SystemVerilog Assertions Handbook
* Using PSL/Sugar
Think this in more hardware way:
When see a rising edge, then a mux is created, i.e., the control line of the mux is also determined by the rising edge.
may b its nt synthesiable
AFAIK, it is perfectly synthesizable.
Ajeetha,CVC
* New Book: A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
* SystemVerilog Assertions Handbook, 2005 ISBN 0-9705394-7-9
* Using PSL/SUGAR
Design Verification Consultant,
Contemporary Verification Consultants Private Limited,
Bangalore, India, http://www.noveldv.com
hi aji, you are absolutely right. its synthesizable and its easy on the eyes while debugging.
Above code simulates and synthesizes
regards,
ramana
in assign statement
lhs is continuously assigned
but if we use it in an always block
it is a crime because , always block will be executed only at athe posedge of an event hence we may miss the values
yes, you can do this like this.
it is a mux followed a register.
yes, it's absolutely synthesizable.but , this kind of coding style may not acceptably
in many company.
useing the noblocking assignment would be a good choice when you need a dff.
