Concert 0-3V analog to 0-10V analog
steve85grrr
Newbie level 1
Newbie level 1
Greetings Guys,
First of all, i am not into electronics so i will try to be simple and i would like the same from your part! I have an LPC2468 board and i am using the DAC in ordert to output analog voltage to a lamp. The lamp receives 0-10V input but the DAC has an output of 0-3 V. So do you know an easy way of amplifying the DACs output?
Thank you very much.
Best Regards,
Asterios
Tpetar, this is digital (inverting) level shifter, analog amplifier is needed to apmplify signal from DAC!
How much output current is needed (lamp power)?
