Conceptual Question: Is the sampled value under 1 LSB still accurate in ADC?
elberlee
Newbie level 6
Newbie level 6
Ghent, Belgium
It is always defined that the LSB is the resolution of ADC.
Here I have one example, which confused me a lot.
Example, two different signal are sampled and the difference is made afterwards. When the difference value is less than 1 LSB, is it the result still counted as an accurate one?
Additionally, the two sampled value are averaged 1000 times separately before subtraction, can I think the "sampling + averaging" process improve the sampling resolution?
Many thanks,
Elber
Once accumulated on a single big value resulted from sum of multiple acquired samples, theoretically we are able to determine an extended precision value, due statistically occurrences must be unequally distributed.
Signals below 1 LSB can in fact be detected by means of dithering.
Look for "dithering".
Regards
Z
