Hawaslsh
Full Member level 3
- Joined
- Mar 13, 2015
- Messages
- 164
- Helped
- 5
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Washington DC, USA
- Activity points
- 3,422
Hello all,
AP2191 p-channel
BD2268 n-channel
Sorry if this is a simple question. I am evaluating a few parts for a project where I needed a high side power distribution switch. The switch will be powering a VCO+PLL chip, LMX2820. The specs for the two parts are virtually identical except for the output type; one is an n-channel and the other p-channel. In my understanding p-channel FETS are usually used in high side switches, and typically P-MOS parts are slower and have higher on-state resistances as compared to N-MOS. However, clearly the P-MOS transistor is sized to match the on-state resistance of the N-MOS part. In my application I am not worried about switching speed, I simply need to follow a proper power-on sequence, is there a functional difference between the two parts, and is there a reason one would choose one over the other (besides cost, of course)?
Thanks in advance!
AP2191 p-channel
BD2268 n-channel
Thanks in advance!
