p11
Banned
comparing numers in vhdl
the first code completes comparison in 2ns as shown in testbench waveform , i mean m1 gets 2 at 2ns ...
here just for simulation i made the clock time period 2ns.. i know 2 ns is never acheived in FPGA.. this is just for checking...
now , if i write the below code it needs much time as it has to wait for rising_edge (clk) for every iteration...as i want the process to go faster so i choose the first one ..........but when i try to synthesize 1st one it is not getting synthesized whereas the 2nd code is getting synthesized ... the error showing while synthesizing 1st code is ..........
i am also getting these warnings .....can i ignore this..
here the main aim of the code is to compare all the data of dat memory and to store the equal valued data in dattt....
-- Company:
-- Engineer:
-- Create Date: 21:21:54 11/13/2016
-- Design Name:
-- Module Name: t - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity t is
port(clk: in std_logic;
t1 : out integer ;
t2 : out integer ;
t3: out integer ;
outt : out std_logic_vector (8 downto 0)
end t;
architecture Behavioral of t is
type memory is array (0 to 9) of STD_LOGIC_VECTOR (8 DOWNTO 0);
signal dat : memory :=("001001001","001001001","010011001","010011001","011101001","001110001","010001010","001010010","001011010","010100010");
type memory1 is array (0 to 9) of STD_LOGIC_VECTOR (8 DOWNTO 0);
signal datt : memory1 :=("001001001","000000000","000000000","000000000","000000000","000000000","000000000","000000000","000000000","010100010");
type memory2 is array (0 to 9) of STD_LOGIC_VECTOR (8 DOWNTO 0);
signal dattt : memory2 :=("000000000","000000000","000000000","000000000","000000000","000000000","000000000","000000000","000000000","000000000");
signal j22 :integer :=0;
signal k22 :integer := 1;
signal m22 :integer := 0;
signal m : STD_LOGIC_VECTOR (8 DOWNTO 0);
signal m1 : integer := 0;
signal p1 : integer := 1;
--signal enterdata : integer := 0;
begin
process (clk)
begin
if (rising_edge (clk) ) then
p1 <= 0;
else
end if;
end process;
process (p1,j22,k22,m1)
begin
if (p1 = 0) then
if (m1 =0) then
if (j22 <10) then
if (k22 <10) then
if (dat(j22)(8 downto 0)= dat(k22)(8 downto 0)) then
dattt (m22 ) <= dat(j22) ;
m22 <= m22+1;
k22 <= k22+1;
else
k22 <= k22+1;
end if;
else
k22 <= j22+2;
j22 <= j22+1;
end if;
else
k22 <= 1;
j22 <= 0;
m1 <= 2;
end if ;
else
end if;
else
end if ;
end process ;
t1 <= m1;
outt <= dattt (1);
end behavioral;
-- Company:
-- Engineer:
-- Design Name:
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
--library UNISIM;
entity t is
t1 : out integer ;
t2 : out integer ;
t3: out integer ;
end t;
type state_type is (p0,p1,p2);
signal presentstate :state_type;
begin
process (clk,j22,k22,m1)
begin
if (m1 =0) then
if (j22 <10) then
if (k22 <10) then
m22 <= m22+1;
k22 <= k22+1;
else
k22 <= k22+1;
end if;
else
k22 <= j22+2;
j22 <= j22+1;
end if;
else
k22 <= 1;
j22 <= 0;
m1 <= 2;
end if ;
else
end if;
else
end if ;
end process ;
t1 <= m22;
outt <= dattt (1);
end behavioral;
ERROR:Cpld:1248 - DRC error: too many Asynchronous Set/Resets (AP/AR) in design.
ERROR:Cpld:1064 - Design rules checking error. Fitting process stopped.
ERROR:Cpld:868 - Cannot fit the design into any of the specified devices with
WARNING:Xst:819 - "C:/payel1/p1.vhd" line 79: The following signals are missing in the process sensitivity list:
WARNING:Xst:1306 - Output <t2> is never assigned.
WARNING:Xst:1306 - Output <t3> is never assigned.
WARNING:Xst:1780 - Signal <datt> is never used or assigned.
WARNING:Xst:1780 - Signal <m> is never used or assigned.
WARNING:Xst:646 - Signal <dattt<0>> is assigned but never used.
WARNING:Xst:646 - Signal <dattt<2:9>> is assigned but never used.
WARNING:Xst:1781 - Signal <dat> is used but never assigned. Tied to default value.
WARNING:Xst:737 - Found 32-bit latch for signal <m1>.
WARNING:Xst:737 - Found 32-bit latch for signal <j22>.
WARNING:Xst:737 - Found 32-bit latch for signal <k22>.
WARNING:Xst:737 - Found 9-bit latch for signal <dattt_1>.
WARNING:Xst:737 - Found 32-bit latch for signal <m22>.
WARNING:Xst - Property "use_dsp48" is not applicable for this technology.
WARNING:Xst:1293 - FF/Latch <p1_0> has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_31> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_30> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_29> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_28> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_27> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_26> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_25> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_24> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_23> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_22> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_21> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_20> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_19> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_18> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_17> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_16> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <dattt_1_2> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <dattt_1_8> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_0> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_2> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_3> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_4> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_5> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_6> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_7> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_8> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_9> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_10> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_11> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_12> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_13> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_14> (without init value) has a constant value of 0 in block <t>.
WARNING:Xst:1710 - FF/Latch <m1_15> (without init value) has a constant value of 0 in block <t>.
WARNING:Cpld:1006 - Design 't' has no inputs.
WARNING:Cpld:829 - Signal 'outt<7>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'outt<6>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'outt<5>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'outt<4>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'outt<3>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'outt<1>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<31>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<30>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<29>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<28>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<27>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<26>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<25>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<24>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<23>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<22>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<21>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<20>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<19>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<18>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<17>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<16>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<15>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<14>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<13>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<12>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<11>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<9>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<8>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<1>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<2>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<3>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<4>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<5>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<6>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<7>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<10>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'm22<0>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<31>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<28>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<27>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<26>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<25>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<24>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<23>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<22>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<20>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<19>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<18>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<17>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<16>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<14>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<13>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<12>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<11>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<9>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<10>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<15>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<6>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<5>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<4>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<7>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<8>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<21>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<0>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<1>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<2>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<3>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<29>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<30>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<28>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<27>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<26>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<25>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<24>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<23>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<22>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<21>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<20>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<19>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<18>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<17>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<16>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<15>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<14>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<13>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<12>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<11>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<9>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<8>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<6>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<7>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<4>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<5>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<10>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<29>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<30>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'k22<31>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<0>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<1>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<2>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'j22<3>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 't1<1>_MC.CLKF' has been minimized to 'GND'.
WARNING:Cpld:829 - Signal 'outt<0>_MC.CLKF' has been minimized to 'GND'.
