battery switch ic
what is the power requirement of this ckt?
Added after 1 minutes:
is this is differential or an integral type??^^
Added after 7 minutes:
Intelligent Power Switch ICs
Intelligent power switch ICs are employed in applications that include USB ports and peripherals, notebook computers, battery-charger circuits, and hot-swap power supplies. They consist of a power MOSFET and internal circuits that control their turn-on and turn-off. Also, many of these ICs have protection circuits for undervoltage, overtemperature, and overcurrent.
1. One of these ICs employs a 1.0A current-limited P-channel, MOSFET for high-side load-switching applications. This switch operates with inputs ranging from 2.7V to 5.5V. An integrated current-limiting circuit protects the input supply against large changes in load current that may cause the supply to fall out of regulation. It is also protected from thermal overloads, which limit power dissipation and junction temperatures. The current limit threshold is factory programmed at 1.5A, with a maximum of 2.0A. The quiescent supply current is typically 16µA. In its shutdown mode, the supply current decreases to less than 1µA. This IC is a part of a family of adjustable and fixed products with a range of current handling capabilities. Single versions with adjustable current limit or fixed current limit as well as dual versions with fixed current limit.
2. Another IC is a dual high-side power distribution switch that integrates a 110mW N-channel MOSFET. It is intended for applications where heavy capacitive loads and short-circuits are likely to be encountered. A logic enable input, compatible with 3V and 5V logic, is available in active-high or active-low enable. An internal charge pump controls the power switch rise and fall time to minimize current surges during switching, and also provides the gate drive for the internal MOSFET. Requiring no external components, the charge pump allows operation from supplies as low as 3.3V. If an overload or a short circuit is encountered, the IC limits the output current to a safe level by switching into a constant-current mode and sets the overcurrent logic output error flag low. Continuous heavy overloads and short circuits increase the power dissipation in the switch, causing the junction temperature to rise, but a thermal protection circuit shuts the power switch off to prevent damage. Once the device has cooled sufficiently, it turns on automatically. Under voltage lockout (UVLO) insures that the power switch is in the Off state at start-up.
3. A single-channel, high-side power distribution switch has enable, flag functions and adjustable current-limit from 0.7A to 1.25A. It is optimized for self-powered and bus-powered Universal Serial Bus (USB) applications. Soft-start eliminates the momentary voltage drop on the upstream port that may occur when the switch is enabled in bus-powered applications. Additional features include thermal shutdown to prevent catastrophic switch failure from high-current loads, under voltage lockout (UVLO) to ensure that the device remains off unless there is a valid input voltage present, and 3.3V and 5V logic compatible enable inputs.
This IC supports the following USB requirements:
* Each switch channel supplies up to 700mA as required by USB downstream devices
* The switch's low on-resistance meets USB voltage drop requirements
* Fault current limited to typically 900mA to 1.25A
* Flag output indicates fault conditions to the local USB controller.
4. Another power distribution switch IC serves as the control logic for a system with multiple power sources. The IC directly drives external P-channel MOSFETs to select from an ac adapter and dual battery sources for charge and discharge. It makes the selection based on the presence of the power sources and the state of the batteries. The IC detects low battery conditions using integrated analog comparators and checks for the presence of a battery by using battery thermistor outputs.
This IC provides most of the power source monitoring and selection, freeing the system power management microprocessor (µP) for other tasks. This simplifies development of the power management firmware for the µP and also allows the µP to enter standby, thereby reducing system power consumption.
5. Yet another family of power distribution switches enables seamless transition between two power supplies, such as a battery and a wall adapter, each operating at 2.8 to 5.5 V and delivering up to 1 A. This family includes extensive protection circuitry, including user-programmable current limiting, thermal protection, inrush current control, seamless supply transition, cross-conduction blocking, and reverse-conduction blocking.
6. Another IC has two internal high-side power MOSFETs that implement a single-pole double-throw (SPDT) switch. Digital logic selects either of two switches or no switch. The MOSFETs have no parallel diodes so output-to-input current cannot flow when the FET is off. An integrated comparator prevents turn-on of a FET switch if the output voltage is greater than the input voltage. The switching circuitry ensures that both power switches will never conduct at the same time. A comparator monitors the gate-to-source voltage of each power FET and allows a FET to turn on only if the gate-to-source voltage of the other FET is below the turn-on threshold voltage.
This IC includes slew rate control. A slow slew rate limits the inrush current into the load capacitor. High inrush currents can glitch the voltage bus and cause a system to hang up or reset. It can also cause reliability issues when hot-swaping a load. It slews the output voltage at a much faster rate when the output switches between two inputs. The fast rate minimizes the output voltage droop and reduces the output voltage hold-up capacitance requirement.
