lvshawnlv
Newbie level 6
Yes it is an NTC inrush limiter, a few ohms at cold start and then they run hot (80-100C) and their resistance drops to a fraction of an ohm, they cheap ones do die quite often,
Go to element-14 or similar and buy one rated for the current at 110Vac, say 15 amps min, clean up the board and fit the new ntc and you're away...!
So I'm confused a little bit.. So when i'm being told to short something, where those two legs are sticking out, then it means fuse them together ? and solder them soild? I figured the one I bought was rated for up to 240 so it would be able to handle it better -- even though i dont think I am going to run it off 240, only 120 though...
So Element 14 ... Buy a new NTC from them and attach that to where the two legs are... ??? In the pictures, Those two gold legs where covered by the NTC when it was a whole... so now that its crumbled apart you see the legs now... the NTC that burned up i left by the two legs so that it would show where it was at one time..
Shawn
Can i run this unit without that NTC attached ? and if so will I experience any issues with it to cause a fire? If not ill just jump the two legs together and call it a day. When this unit is on ... it runs for about 1 minute before any load is pulled through it... the load isnt on it 100 percent from switch on to running...
Shawn
